Use the data in the following table to use the UBoot tab.
View UBoot Version and Status
Use this information to verify the integrity of the software and hardware. A representative from Customer Support will instruct you to obtain this information when required.
  1. In the navigation pane, expand Configuration > Edit.
  2. Select Chassis.
  3. Select the UBoot tab.
UBoot Field Descriptions
Name Description
DefaultVersion
Displays the default UBoot version.
AlternateVersion
Displays the alternate UBoot version.
VersionUsed
Displays the UBoot version in use, either the default or alternate.
TrustedDeliveryStatus
Displays the status of the chain of trust image signature validation steps.
